SManZ350
I have a new Kioti CK2610 and I bought a subsoiler over the weekend. I took the rear blade off and put the subsoiler on and had questions my owner's manual didn't cover, so here I am!
This is a pic off the web, but mine looks identical.
The lower lift arms each have a turnbuckle that limits the movement of the arm towards the centerline of the tractor. Using these I was able to center the implement and tighten them down to get rid of any side-to-side slop.
Should these turnbuckles be adjusted to allow for no slop or some slop? Or does it depend on what I am trying to do or what kind of implement I'm using?
The Cat 1 pins on the implements have a lynch pin that keeps the lift arm from sliding off. It seemed that when I got rid of the side-to-side slop that the outer edge of the lift arm was putting more pressure against the lynch pin since the turnbuckles pull the lift arms outward. Is this ok?
Thank you!
.jpg)
Thank you!
