AGTtactical
- Joined
- Sep 16, 2018
- Messages
- 200
- Tractor
- Kubota SVL95; Kubota L6060HST
I've been back and forth between the RBT3596 and the RB3796...
RBT3596: 795 lbs, 30" of offset, hydraulic options in angle, offset, and tilt. $2500 without any hydraulic cylinders. This blade is heavier, has some really good offset reach, and you have the option of adding hyds to all three functions (angle, tilt, and offset) if you decide you need them at a later date. I have a TNT kit, so I don't need tilt, but having the option of angle or tilt is nice. This blade uses identical cylinders for blade angle and offset, so you could buy just one cylinder until you see which function you use the most...blade angle or offset. If I ever sold it, some people might want all 3 hydraulic options.
RB3796: 665 lbs., 26" of offset, only one hydraulic option (angle). $1550 without any hydraulic cylinder. BUT you can swap the blade for a rake by pulling the king pin, removing the blade, and swapping in a rake. The rake is about $1200 extra just for the rake. Tilt only comes in 15-30 degree angles (not ratchet like the RBT35). Its quite a bit weaker than the RBT35, even though the horsepower rating is the same.
Any thoughts from the pros out there?
http://https://www.landpride.com/products/123/rbt35-series-rear-blades
http://https://www.landpride.com/products/567/rb37-series-rear-blades
Many thanks to Dana Trumpp at Landpride for his help in narrowing this down...SUPER GUY.
