Rear blower for Massey gc24
   / Rear blower for Massey gc24 #1
whoodle
N. Vermont
JD 110tlb, rtv900.
Hi Folks,
I am thinking of a Meteor 60 or 68 for this little tractor. I do not have a fel. The area I intend to clear is dead flat and paved. About 6000 square foot rectangle between a building and a road. Most of the time the snow will be less than 8 inches with and very rare 20 plus. I'd like to have the 68, but I wonder about the 510 lbs load.
Anyone try this?
   / Rear blower for Massey gc24 #2
I think you'll need some front weight...
I have a Kubota BX24(similar size tractor, I believe), in winter I remove the FEL & BH and mount a 3pt 52" snowblower.
I now mount a 5 gal plastic pail full of concrete on the front of the tractor to keep the front end down when I move forward with the blower raised.
Pete
   / Rear blower for Massey gc24 #3
For $2400+, I'd rather have a FEL and 72" rear blade. That way the blower isn't just laying around all summer, and you don't have to drive backwards all winter. But, I don't know what your conditions are, so a big blower may be best. Did you know that SCUT deeres only come with 47" or 54" blowers? I think it's awfully optimistic for your tractor to handle that meteor 68".
   / Rear blower for Massey gc24 #4
I would look for a blower in the 50" range, a 60" would be to big. Your neck will get tired with a rear blower. Have you thought about a front blade?
Pete
I thought #500 would be a bit hefty. My 4' bush hog requires weight on the front as well. I have a Jd 110 tlb for summer, and an 84 inch blower and front V-plow. I just have the little red tractor for mowing and blowing my commercial building.
   / Rear blower for Massey gc24 #6
Something like a Meteor SB51 it is 366lbs should work good but you still may have to put 100lbs on the front or a Agro trend 1054.
   / Rear blower for Massey gc24 #7
for only 6000 sq ft I would use a rearblade or your fel to push it.
I went with the 60 for higher ground speed and lower weight.
   / Rear blower for Massey gc24 #9
A tractor mechanic told me a general guide for pto attachments is 5 horsepower for each foot the moving part is wide. A 6 foot blower requires 30 PTO HP. Same with a mower etc...
   / Rear blower for Massey gc24 #10
I have a 78" smythe on a mf 28hp, in Maine. Plenty of power to blow snow in slow reverse. You are going to need a hood and googles:p. Nice thing about the blower is you don't have to plan for a winters worth of snow piles before the first flakes fall.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2016 FREIGHTLINER...
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
Skid steer auger plate (A50322)
Skid steer auger...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
