rear lift chatter 72 ford 3500
   / rear lift chatter 72 ford 3500 #1
adamjoy
maine
1972 ford 3400
3pt hitch chatters on the way up and it wont stay up sometimes, was told this means the pump isn't getting enough fluid. was also told there are multiple modes for the draft? what is draft? is there a screen thats clogged somewhere? also 3 cyl diesel starts hard, having a hard time finding the part number for new glow plugs. anyone got ideas?
   / rear lift chatter 72 ford 3500 #2
   / rear lift chatter 72 ford 3500 #3
lots of questions here.
1, check to see if you do indeed have enough fluid in the rear compartment for hyds and rear diffy.
2, do you actually have a thermal start aid or not? ( not glow plugs ).
3, yes, there are screens.. but lets look at #1 first.
4, on the draft. if you have 2 levers in a double quadrant, you have an adjustable draft control. I have seen these on the X600 and up.. but I'm not sure on the 3500. If you have a single 3pt handle, and then a separate small short lever ont he lift cover, it's either draft on/off selected, then use the 3pt lever for setting sensitivity.
LASTLY, if you do have plenty of fluid.. see if it is dirty or wet... either can cause things like control valves and unloaders to stick, in addition to wet oil having frozen chunks inthe winter, and water vaporizing in a pump to cause cavitation.
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
2018 LAMAR TRAILER 40' T/A GOOSENECK TRAILER (A53843)
2018 LAMAR TRAILER...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2012 INTERNATIONAL WORKSTAR 7500 HYDROVAC GUZZLER TRK (A53843)
2012 INTERNATIONAL...
