Rear Link Stutters when lowering.
/ Rear Link Stutters when lowering. #1
bcp301
eastern massachusetts
BX-2230
I am the proud owner of of a BX2230 and am noticing that when I lower the rear blade to scrape the nasty white stuff and ice from the driveway, it takes a couple of seconds more than it used to due to it stops mid way and then releases. Any thoughts?
/ Rear Link Stutters when lowering. #2
I would make sure the linkage under the tractor that goes to the midmount mower isn't moving or binding. It should be raised all the way up, with the hight adjustment knob set at top. Also check to make sure your arms pins aren't rubbing/binding against anything.
/ Rear Link Stutters when lowering. #3
flow control needs to be opened a bit more ?
/ Rear Link Stutters when lowering. #4
You have received excellent advice from radioman and Matt, ---my bet is flow control is closed a bit to much. You could have brushed it getting on and off tractor.
DevilDog
/ Rear Link Stutters when lowering. #5
One thought I also have is check your HST fluid level. when raising the 3 pt, and if the fluid is low, it will suck air (bad) causing it to stop. check the level from the orange dipstick in rear by PTO.
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2002 CHEVROLET 3500 FLATBED TRUCK (A64278)
2002 CHEVROLET...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
2006 Ford E-250 Cargo Van (A64556)
2006 Ford E-250...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
