rear pto not working
   / rear pto not working #1
monitos
standforville, new york
massey ferguson, ford, kubota, international
Hello all,
The rear PTO on my Massey Ferguson 1250 has stopped working. The switch is on and the light on the dash confirms that. The lever is in in the 540 position. The lever used to have some resistance to it while shifting in and out but now it just seem too easy to move back and forth. I know something has broken. This PTO is an independent electro-hydraulic. Has anybody had a similar problem and can anyone point me in the right direction. Thanks.
   / rear pto not working #2
Have someone play with the lever while you look at the back etc, follow the rod movement and see whats going on. Could be just a bolt that has vibrated free.
Lever controls a shaft that goes directly into the PTO housing. Shaft is moving. I am afraid that I need to tear it apart to see what is going on inside
   / rear pto not working #4
Is this a shaft that turns? Or moves in and out? If it turns (as has a lever on it) check for a roll pin that has sheared. You may not be getting full movement of the shaft. Just my guess.
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
Flat Bottom Boat w/ Trailer (A51573)
Flat Bottom Boat...
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2023 Bobcat E32i Mini Excavator (A51573)
2023 Bobcat E32i...
