rear remote issue
   / rear remote issue #1
savagesultin
Savage Harbour, PE
Case Farmall 55
I have a 2009 DX55 and I have two rear remotes. One I'm having an issue with, it will work one direction but when I put the lever in the opposite direction is doesn't work. I have a snowblower attached and one way it will rotate the drum to the left when I push the lever the other direction it won't go back to the right unless I push it hard a couple of times then it will work very slowly. I plan on removing it but thought someone might be able to help troubleshoot it as well. I don't want to replace the valve but might have to.
   / rear remote issue #2
Have you tried the snowblower on the other rear SCV? That is, have you verified it's the SCV and not the snowblower's cylinder?
   / rear remote issue
yes I've switched it from the rotating drum to the chute and same result
2007 International 9200i Truck (A48561)
2007 International...
2017 Dodge Grand Caravan (A46684)
2017 Dodge Grand...
SCAG Turf Tiger II Zero Turn Mower (A46684)
SCAG Turf Tiger II...
New Holland 855 Round Baler (A49339)
New Holland 855...
Skid Steer Plate w/5/16in. Guard (A46502)
Skid Steer Plate...
2000 HEIL  44FT TANKER (A45678)
2000 HEIL 44FT...
