Rear remote...
   / Rear remote... #1
IH782
NEPA
Kubota 2650 Kubota B7800, Kubota L3901, Mahindra 2538, Mahindra 2555
Anyone know what the part numbers are for the rear remotes for the 2555. I need 2 more.
   / Rear remote... #2
Depending on the depth of your pockets, you may want to just look at standard parts and fab your own mounting. The factory kits from Mahindra are quite expensive. According to their build site, the second spool kit is $565 when ordered with the tractor:
2555 HST | BYO Mahindra
A dealer will want more. I'd expect it will be a grand if they do the install.
   / Rear remote... #3
Sysop's link looks like you can add a 2nd ($565) & 3rd ($585) spool kit.
I say this, somewhat surprised, because on some tractors there is not the physical space for more than 2 spools and/or their associated levers, linkage, connectors, etc..., unless you go to a more "custom" installation.
   / Rear remote... #4
Fact that there is lots of space is all the more reason to build your own. Cutting, bending, and drilling some bits to make mounts is much easier when there is room to work. Plus you can choose the capabilities of the valve according to your wishes and not just what the manufacturer happens to decide what is most common.
Price is much better doing your own, even as a learning experience.
1 SPOOL 2 SERIES PRINCE STACK VALVE POWER BEYOND
   / Rear remote... #5
When I bought my new 2008 Mahindra 5525, I had the dealer install triple rear remotes (his own design). Cost: $750.
   / Rear remote... #6
Do you even need the 20 series, unless you are powering a hydraulic motor from the remote? if just cylinders, go smaller valve?
1 SPOOL PRINCE SV SECTIONAL HYDRAULIC CONTROL VALVE OPEN CENTER W/POWER BEYOND
   / Rear remote...
Thanks for all the replies. The tractor came with 1 remote, it can accommodate up to 3.
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Crown RC5535-35 Stand-On Electric Forklift (A59228)
Crown RC5535-35...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
CATERPILLAR M322D...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
