Rear Wheels for YM1301D
   / Rear Wheels for YM1301D #1
gbirky
Platinum Member
Near Hagerstown, MD
Yanmar models: YM1110D, YM1301D
I would like to get an extra set of wheels for my YM1301D so I can put the original 8-16 rice tires on them for winter use. Does anyone know if the center hole and lug bolt holes are the same as wheels for the YM1401D? I can measure them to compare if someone has the measurements.
Also, anyone have a set of 16 inch Yanmar wheels they want to sell?
   / Rear Wheels for YM1301D #2
Greg I have a complete set of turf tires & rims for a ym 1401
they are mounted on the rims for 450.
I dont know if you would rather have turfs
Ernie
Thanks for the offer Ernie. Unfortunately, that doesn't help me. I have removed the original rice tires, and put 265/75R16 truck tires on the original rims. I use this configuration for yard work as they work just like turfs. Now I would like to have another set of original size rims (narrow) to mount the original rice tires on so I can plow snow this winter without having to put tire chains on.
Anybody else out there want to sell a set of original (narrow) 16" Yanmar wheels (6 bolt)?
   / Rear Wheels for YM1301D #4
I have some rear rims off a ym155 here, will those work?
Ernie
I don't truely know. What I have is 16" diameter and I believe 6" width. I need to mount 8-16 R2 rice tires. I'll have to measure the pilot hole and bolt circle tonight and get back with you. Also the wheels have a significant offset which I will also measure as best I can. I would have to know if my measurements match the wheels you have to know if they would work.
   / Rear Wheels for YM1301D #6
Greg- I did what you did about a year ago- took my rice tires off and mounted truck tires in their place. I contacted Hey Wheel Co. and they can make a set of wheels for around $150, I think. I never got around to it, and I find that I like just using the truck tires. I have good traction all the time, except in muddy clay, which I try to stay out of anyhow. I still may have the wheels made up for the few times I need the extra traction.
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A53472)
Toyota 6FGU25...
New/Unused 2025 H12R Mini Excavator (A51573)
New/Unused 2025...
