rebuilding a 3204 cat engine and have a few questions
   / rebuilding a 3204 cat engine and have a few questions #1
Little General
Bronze Member
Mi. Pleasant , N/C/
Kubota M7060 w cab Kubota x1100c Kubota KX008 John Deere 4400 , JD TLB110
I traded an old 4 wheeler for a 1992 Cat 943 that has seen better days...but I only have $500 in it so what the ****. Got the motor out and I am having problems removing the fuel injection pump and the front engine case. The fuel injection pump shaft just will not push out of the gear and something near the dowl pin in the lower left engine case wont let loose. Any ideas?
   / rebuilding a 3204 cat engine and have a few questions #2
Have a look here in the Cat section and see if you can find something close. If there are any hidden tricks they should be addressed to get things apart.
Thanks , I will give it a read.
   / rebuilding a 3204 cat engine and have a few questions #4
Try posting on heavyequipmentforums.com
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2007 Ford Fusion SE Sedan (A48082)
2007 Ford Fusion...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A50860)
2012 Big Tex T/A...
DAEWOO GC255-2 FORKLIFT (A50854)
DAEWOO GC255-2...
