Loader Recall on FEL
   / Recall on FEL #1
Nissan197
Platinum Member
Kansas
Mahindra 3215 4WD
I finally got my 2006 3215 in to the dealer for them to beef up the FEL which was a recall from Mahindra. I just got a call from them saying there is a broken bolt in the center housing which needs to be replaced. The dealer said more than likely it was caused by the FEL not being properly supported and that when they called the Mahindra service rep they will not pay for it. It should not cost more than $160, which I thought is crazy but I do not know what is involved. The tractor only has 255 hours on it and the hourmeter also stopped working. They said to replace that is around $500 - $600. The hourmeter just can't be replaced. The whole assembly has to. Just a little frustrated since I do keep up on the maintenance and now things are starting to fall apart on the 3215. Has anyone else had the same issue with a broken bolt on the housing or an inoperable hourmeter?
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
434669 (A48836)
434669 (A48836)
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
