Reducing hydraulic power on my Kubota
   / Reducing hydraulic power on my Kubota #1
scornett
Canyon, TX
Kubota 9540
I'm wanting to use my tractor remotes on an old dump trailer. The trailer's hydraulic unit is rated to 2000 lbs. My Kubota 9540's owners manual says I can reduce the pressure with a valve on the back. It says there is 1 1/2 turns of adjustment. How do I determine when I've got it under 2000?
   / Reducing hydraulic power on my Kubota #2
Are you talking about relief pressure.
You figure the force in lbs on a hyd cyl by using the bore diameter and the pressure capability of the pump.
There is the straight on push force and then you have the angled push force which is less.
The hyd cyl will develop the pressure by the load placed on the cyl.
The relief valve will regulate the max pressure the cyl can develop.
You need a hyd gage to adjust the pressure.
If your cylinder is a 2500 psi cyl, then you can regulate the pressure that the cyl can achieve by setting the relief valve to about 2450 psi. .
   / Reducing hydraulic power on my Kubota #3
If you meant 2000 psi (pressure) rather than 2000 lbs (weight or force) then you need a pressure gage with a mating quick disconnect to plug into the rear remote you plan on using with the trailer. Briefly activate the remote to read the pressure.
Yeah, psi. Thanks, guys. I'll scare up a pressure gauge. Maybe the dealer will loan me one.
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
Cat TH407C Telehandler (A53472)
Cat TH407C...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
