Mrwurm
Veteran Member
- Joined
- Jan 20, 2002
- Messages
- 1,569
- Location
- South East Michigan
- Tractor
- New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
Remote Fused Disconnect \'Melt Down\'
Ok, so you're probably wondering what this thread is about
Here's the biz:
I have a 'Hot tub' or 'Spa' at my home. The electrical hookup goes like this:
50 amp 220 volt breaker in the main house panel is connected to about
100 feet of #8 wire (or maybe #6) that snakes it's way to the remote fused
disconnect. The disconnect is rated for 60 amps max and a 45 amp time-delay
fuse is installed on each leg. Wiring then leaves the disconnect and travels
about six feet to the final connection at the 'hot tub.'
Now, why have I said all this
It appears that the 20 year old pump has finally siezed up and died. But, the
old pump was not satisfied to go quietly, it was determined to take other casualties
along with it.
Close investigation has uncovered the following information:
1) The 50 amp breaker at the main panel did not trip.
2) One of the 45 amp time-delay fuses died.
3) And finally, all of the plastic components in the remote disconnect have melted down
to a distorted mess. Actually, only the side with the blown fuse melted.
So, I've said all this to pose one question . . .
What good is a fuse if takes so long to blow that it allows an $80 disconnect box to
melt down and become useless ?
Here's the biz:
along with it.
