remote hydrolic
   / remote hydrolic #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
where should I look for a remote hydrolic out put on my shibaura s1500 fourcylinder or where can I tap into to to .
   / remote hydrolic #2
What do you have for hyd now. Pump, 3pt. Anything else?
Do you have a loader, and if so, does the loader valve have a PB port?
   / remote hydrolic
no loader but it has bolt holes in trans for loader the hydrro pump is in front of engine with pipe running to rear. is there a way to split the pipe .
   / remote hydrolic #4
If you have bolts that cover hyd ports, then use the pressure and return ports for loader , remotes or whatever.
To check for pressure, take a 3000 psi hyd gage and adapt it to the bolt holes and check the pressure.
If you have an external pipe, you can cut and install fittings to install a loader valve.
Be sure and get a loader valve with PB.
You could also do the remotes at the same time for T-N-T, etc.
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2017-2023 Ford 4x4 Super Duty Pickup Bed (A49461)
2017-2023 Ford 4x4...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
