Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)?
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #1
wisconsitom
Bobcat ct2025 HST
Hey all, wanting to weld some expanded metal to my brush guard. 4 bolts hold unit to tractor frame. These bolts are not secured by nuts, but simply deadend in the frame...and they are tight! I mean putting all I dare on my good 1/2" socket, can't move em. I'm laying ony back underneath with great leverage and I think I might break some ribs if one of those bolts would start to spin!
Any ideas what a guy's got to do to get these 4 bolts out?
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #2
Can you rent an impact wrench? Or a Good excuse to buy one if that’s an option. As I get older I’ve found that I grab mine more than before….😉
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #4
Prolly damage the paint with heat…🤷
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #5
What a rattle can is for.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #6
Before I'd get into ruining paint, an impact or a breaker with a long cheater I could step on away from the FEL. The smoke wrench is last resort but does get plenty of use around here.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #7
I used my Dewalt bat operated impact wrench and an impact socket, worked quite well.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #8
Make sure to use a 6 point socket on this. Gives you more surface contact.
Thanks all. When I get back up there, will start with battery power impacts.....go from there.
Yeah, still nice paint where bolts attach-wouldn't mind not sizzling that off if I don't have to.
   / Remove brush guard bolts-Kioti ck2610 (actually bobcat 2025)? #10
2000 Trail King Step Deck (A49461)
2000 Trail King...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
