Buying Advice Remove cab door
   / Remove cab door #1
melgibson
Bronze Member
Does anyone have any advice on how to remove the door on a 5600 D?
   / Remove cab door #2
Did you get it removed?
   / Remove cab door #3
From what I read on a thread here, the person said to take the bolt out of the limiting strap and lift the door out of the hinges. Simple.
   / Remove cab door #4
Yep that's all there is to it. Took off mine to adjust door fit (wack on welded brackets on cab)
   / Remove cab door #5
Thanks for the update. Now I know how to remove a door in case I need to wack the brackets. :D
   / Remove cab door #6
TCRanger here. Recently removed the passenger door to repair damaged door latch assembly. In addition to removing the screw on the strap, I had to lubricate the hinge pins, then lever/jack up the door as its a bit heavy to handle...a two man operation for us. It went back on easier than it came off though. Gravity is a wonderful thing when it works in your favor.
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
PICK UP BED (A49461)
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
