Remove top of hydraulic cylinder
   / Remove top of hydraulic cylinder #1
althor
Hi, I am looking for assistance in removing the top of the hydraulic cylinder on my Kioti backhoe to change the seals.
I have the cylinder off and I have a pin spanner in the hole on the side of the cylinder and I have tried removing the top by both counter clockwise and clockwise pressure, with no result. Can someone help me with a next step?
   / Remove top of hydraulic cylinder #2
Can you post a picture so we can see what type of cylinder it is? Have you tried any heat to the glad nut?
Here are a few pics. I have tried nothing but pressure and will try anything you can suggest, thanks
   / Remove top of hydraulic cylinder #4
I would put it back on the hoe to hold it really stable, add some heat (like propane) and try again with steady pressure on the wrench. You can also try tapping the nut with a brass or lead hammer with pressure applied. Don't hit the wrench or you may shear the pin.
Thanks kennyd, I will give it a try in the morning.
   / Remove top of hydraulic cylinder #6
squeezing the barrel close to the nut can work against you if the barrel wall thickness is not heavy.....best to grab in the vise at the cyl base end with a junk pin wedged in the mounting hole
also, if you have one avail, use an air-impact hammer with a blunt tip.....use it parallel to the hyd rod (slightly tipped toward loosening) and shock the nut while trying to unscrew with some other help to untorque...be carefull to not use it where the outside threads are on the nut, it may make more work for ya:thumbdown:
   / Remove top of hydraulic cylinder #7
Not sure how strong that pin spanner is, I have had 100% results with pipe spanners (Stilsons) and an associated breaker/cheater bar (4 foot long metal pipe) - if you think your spanner can take the pressure then slip the pipe over the end for extra leverage.
   / Remove top of hydraulic cylinder #8
Like KennyD says, I have always found it easiest to leave the cylinder connected to the machine to loosen the end cap. 4" cylinders that haven't been touched for many years on a 40 year-old backhoe weren't too much trouble with a spanner and extra leverage in the form of a length of metal water pipe as I mentioned previously. Good luck.
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
