Rotary Cutter Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter
   / Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter #1
MarkGrabb
BURNT HILLS, NY
Massey Ferguson 1759
Hello All
I see a lot of discussion on this topic, but I don’t see a post that addresses this issue.
I have a castle nut with a cotter pin holding my blades on my Rotary Cutter. I am want to remove the blades for sharpening. I got the pin out of the castle nut. I have a large socket for the castle nut on a 1 inch drive. When I turn the nut, the blade bolt just spins. The bolt doesn’t have a section for a wrench like I see on another blade bolts. It seems like I need to grip that circular end of the bolt with something. Is that right? Would a pipe wrench work? What is the best way to do this?
Many thanks,
Mark in Burnt Hills, NY
   / Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter #2
Hello All
I see a lot of discussion on this topic, but I don稚 see a post that addresses this issue.
I have a castle nut with a cotter pin holding my blades on my Rotary Cutter. I am want to remove the blades for sharpening. I got the pin out of the castle nut. I have a large socket for the castle nut on a 1 inch drive. When I turn the nut, the blade bolt just spins. The bolt doesn稚 have a section for a wrench like I see on another blade bolts. It seems like I need to grip that circular end of the bolt with something. Is that right? Would a pipe wrench work? What is the best way to do this?
Many thanks,
I just sharpen the blades on the machine. I use an angle grinder and am done in less than 10 minutes.
   / Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter #4
Can you lock the PTO shaft side to keep whole gear assembly from spinning?
Dale
   / Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter #5
An air gun would probably get it off rather than the pull handle. Other option would be a pipe wrench on the bottom of the bolt or tack weld it with the pull handle on top.
   / Removing Blade Bolt on Taylor Pittsburgh Rotary Cutter #6
Stillson on the bottom, impact on the top. Breaker bars won't work. You need the impact action to break the nut loose.
Thanks all - and thanks 1010. Pipe wrench on the bottom and a cheater bar on the 1 inch drive breaker bar and socket on the top did it!
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
