Backhoe Removing blades on BH RDTH 60
   / Removing blades on BH RDTH 60 #1
tld
Boston, GA
JD 2025r
It's been about 5 years since I have removed blades for sharpening.
Should the bolts be turned counterclockwise to remove. I'm getting a lot of resistance and don't want to break a bolt. I don't have a grinder to do it w/o taking them off.
   / Removing blades on BH RDTH 60 #2
I didn't look to see what the recommended torque spec's are, but I'm guessing it's over 450ft-lbs. So they wont just loosen up, but they'll break loose with a snap. I did my blades this spring and I needed a friend and a 5 ft breaker bar to get the nuts off. I moved the BH to the middle of the yard and it was a good thing too. Because each time the nut's broke loose my friend ended up sitting on the ground. I now have 3/4" air ratchet to make this a bit easier.
I'd recommend if you can get an air ratchet with enough torque that would be better.
Oh ya, they should be Counter clock wise to loosen, just like any other nut/bolt.
Wedge
2015 FORD F350 SERVICE TRUCK (A51222)
2015 FORD F350...
2002 International 9200i Truck (A52128)
2002 International...
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
vin:16VEX2023H3042174 (A50322)
vin:16VEX2023H30421...
2011 Cadillac SRX SUV (A50324)
2011 Cadillac SRX...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
