removing crankshaft pulley on 755
   / removing crankshaft pulley on 755 #1
mitch_lojek
michigan thumb
mf 1010
trying to strip down engine for rebuilding. having trouble removing the crankshaft pulley. the FSM says to remove the bolt and washer and use a 2 jaw puller. having done that, I went to a 3 jaw puller and tighten it to the point of shearing a few bolts right off the puller. still no luck! I tried tapping with hammer while tightening the puller and even heated pulley with torch.
did anybody else have this kind of problem, if so, how did you overcome it. any help would definitely be appreciated.
   / removing crankshaft pulley on 755 #3
I have done 3 or 4. I used a good 3-jaw puller after loosening
the bolt. I put the center screw of the puller on the head of
the bolt. After tightening the puller, I whacked the puller
with a hammer. Only once. Is your puller acting on the head
of the bolt?
   / removing crankshaft pulley on 755 #4
of the bolt?
yes, I did it exactly the way you decribed it and it did not budge. as for whacking it, I did hit it but was afraid I might damage something. I also used PB blaster. no luck. I'm now in the process of making a fixture to use a bottle jack. maybe that will work.
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2007 DRAGON 150...
