Removing Pop Rivets
   / Removing Pop Rivets #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
What's the proper method for removing pop rivets?
I have to replace a broken hold down strap and it's held on by 2 different sized pop rivets;
1/8" x .232 and a 1/8" x .294.
Do I use a 1/8" drill and drill them out? A 1/16" drill? /forums/images/graemlins/confused.gif
   / Removing Pop Rivets #3
Mike, you'll want to drill the same size or slightly smaller than the original holes. Of course, that's easy to say but impossible to see the original holes with the rivet in there. If they are the "standard" small pop-rivets it's usually 1/8 inch. 1/16 drill might be a tad small. You can also use a larger drill bit but only drill down until the rivet head comes off. The cone angle of the drill bit will usually keep you out of the base metal. Vise grips on the backside if they spin /forums/images/graemlins/smile.gif
   / Removing Pop Rivets #4
Just a note - if they do start to spin, angling the drill some generally cuts the head off even while it's spinning.................chim
198367 (A51243)
198367 (A51243)
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2013 John Deere 450J LT (A47477)
2013 John Deere...
