Removing rust from gas tank
   / Removing rust from gas tank #1
Jeff396
Veteran Member
South Carolina
Kubota B7500
I am in the process of trying to remove rust and some buildup from a motorcycle gas tank when some fuel went bad. So far I have tried throwing in a bunch large nuts and shaking it which seems to be working somewhat but I think my arms will fall off before I get anywhere. Does anyone have any suggestions on how to clean out the inside of my tank? I know Eastwood has a kit to clean and seal the tank but I'm not too sure I want to use the sealer which is about half the cost of the kit.
Jeff
   / Removing rust from gas tank #2
Nice bike, Jeff! Reminds me that the first historical reference to a motorcycle was in the bible: "Joshua's Triumph was heard throughout the land." Corny, I know. Sorry.
I'm not sure if they show it on their website, but POR15's printed catalog has a step-by-step on how to clean a gas tank. Check their webpage, and if you don't see the instructions, order their catalog online.
Hope this helps. Pete
   / Removing rust from gas tank #3
Here's a link to a method for removing rust. I haven't tried it, but I've heard it works slick as a whistle.
<A target="_blank" HREF=http://users.interconnect.net/nlindsey/rusty2l/electrolysis/electrolysis.htm>rust removal by electrolysis</A>
HTH,
Dave
   / Removing rust from gas tank #4
Work bench vise needed. Gently clamp a vibrating sander pad side up, strap tank to pad where sand paper goes. Add steel shot and light oil. Turn on sander and watch for slippage, Turn off sander, retighten straps, go for it.
This worked for a lawn-mower tank, a motorcycle is not much different ;)
   / Removing rust from gas tank #5
Here's a <A target="_blank" HREF=http://www.por15.com/index.html>link to POR-15's website</A> for you.
Thanks, it looks like they sell the rust remover separately so I think that's the route I'll take. The electrolysis sounds interesting but I'm not sure it would be okay for a painted tank. I also managed to find a variation on the sander idea. They suggested borrowing a mini cement mixer and putting a bunch of broken safety glass in the tank, put the tank in the mixer and turn it on. Of course you would have to pack the tank in with foam but I think they were using this method for car gas tanks where finish wasn't as much of an issue. Do you think the rust will stay away if I don't let the gas turn again or should I consider the sealer?
Jeff
   / Removing rust from gas tank #7
Gas tanks used to be lined with a lead coating to prevent rust. I'm sure they have used other coatings. If you use abrasives to remove the rust you are going to remove the rest of the coating. It's already gone or was never there in the spots that rusted. Coat it and save yourself a future PITA.
Thanks, it never occurred to me that gas tanks were coated to prevent rust......duh./w3tcompact/icons/smile.gif I guess I'll go ahead and spring for the entire kit. It's funny, I've owned this bike for some 24 years and never noticed the problem until the gas turned a couple years ago.
Jeff
   / Removing rust from gas tank #9
<font color=blue>The electrolysis sounds interesting but I'm not
sure it would be okay for a painted tank</font color=blue>
One of the advantages of electrolysis is that it attacks only the iron oxide (the rust). The bath is just baking soda and water, so it's inert itself.
What ever process you use, seal the tank afterwards or you'll for sure will be fighting rust again. Whenever I'm restoring an old car or piece of construction equipment one of the first things I do is remove the tank and send it out to my local radiator/gas tank shop. They use a process called "plasticizing" to clean and seal the tank with a plastic coating. Costs me around 75-150, depending on size of tank. I haven't seen the home use kit, but I suspect it uses a similar process.
Dave
I just ordered the POR15 tank repair kit for motorcycles online. It comes with a degreaser/cleaner, a rust remover and the sealer. With shipping it totaled about $33.00. I'll let y'all know how it works./w3tcompact/icons/smile.gif
Jeff
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
UNUSED LANDHONOR LHR-SB2T3M CHAIN LEVER HOIST (A54757)
UNUSED LANDHONOR...
Water-Reel Irrigation Reel (NO LEAKS)(LIKE NEW) (A50775)
Water-Reel...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
