Mowing Removing spring tension on mower deck
   / Removing spring tension on mower deck #1
nhman
Virginia
Kubota B2910
any tips for getting the spring off the mower deck for winter storage? I want to remove the tension to save the belt. I can pry it off, but want to ensure I don't hurt myself!! or scratch the heck out of the deck.
nhman
   / Removing spring tension on mower deck #2
I am about to do the same thing as soon as I find a spring puller. I am going to check Home Depot and NAPA. It is a tool with a hook and usually a T-handle to hold on to. That spring has a lot of tension and as you said I don't want to be on the receiving end. I know someone who got hurt pulling a large spring off with channel locks. I would get a spring puller for the job.
   / Removing spring tension on mower deck #3
I use a auto drum brake spring removal tool,it works very well and is sold in auto parts stores.
   / Removing spring tension on mower deck #4
Gee guys, I just turn one of the blade pulleys while pulling the belt off the pulley, letting it walk itself off. It only takes a minute and I dont have any problems at all, and no tools to make/buy. Goes on just as easy....
   / Removing spring tension on mower deck #5
Just did mine yesterday, I just use a pr. of ViseGrips and grab the spring at one end and pull! Do the same thing when I put the spring back on at the start of the season. Works like a charm, and I already own the right tool!
   / Removing spring tension on mower deck #6
I attach a 4' piece of chain (like you tie the dog out with) and hook it over the end of the spring end on the idler pulley. Then I use a screwdriver thru the chain (to form like a t-handle) to pull the spring. This takes tension off the belt and have an assistant remove the belt from the pulley whilst I hold the chain. Then I can slowly release the chain and the idler pulley. Reverse the procedure in the spring.
1982 TANDEM AXLE CEMENT MIXING TRAILER (A45333)
1982 TANDEM AXLE...
2073 (A46502)
2073 (A46502)
KC 28in.x90in. Metal V Bottom Feed Bunk (A46502)
KC 28in.x90in...
Antique Kinkade Garden Tractor 36in. Sickle Mower (A46502)
Antique Kinkade...
6in. Hydraulic Auger (A49339)
6in. Hydraulic...
320 Gallon Flat Bottom Poly Tank (A47369)
320 Gallon Flat...
