removing the dash workmaster 45
   / removing the dash workmaster 45 #1
geribilly
Molong NSW
2012 new holland workmaster45
Hello
My workmaster45 has been attacked by rats behind the dashboard.
I would like to remove the dash so that i can rewire but am having trouble removing the turn signal and the light knobs so that i can access more easily.
At present it turns over but will not start. i have checked and there is no power to the fuel solanoid
Does anyone have any suggestions
   / removing the dash workmaster 45 #2
I can't help with your dash but if it makes you feel any better the vermin got to my NH 545 too. Just like yours, they chewed on something behind the dash or somewhere in between. The fuel solenoid doesn't work with the key anymore. Until I can get to it, I have it jumped out.
Thanks, I had a feeling I would not be the only one, they chewed the wiring in my shearing machine as well. hungry little buggers.
   / removing the dash workmaster 45 #4
if you have power at the fuse block, come off the fuse block and go to the fuel solenoid. the fuse block is switched so you can turn off the fuel with the key. this may get it running-at least.
Thanks i will try that.
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
