removing the hydraulic strainer on a 2444
   / removing the hydraulic strainer on a 2444 #1
Chantyr
Algonquin, Illinois
IH 2444
I am trying to remove the strainer for the hydralic fluid out of the front of the resivor casting. The tube that is part strainer assy is to thin to be able to grab on to, does anyone know if there is a tool for this, or has anyone made a tool to grab this from the inside of the tube? Not sure if i should heat this or what the trick is, I had it out a long time ago it just presses in and has an o-ring around the outside of it to seal. Not sure if something corroded, any ideas would be great,
Brandt
   / removing the hydraulic strainer on a 2444 #2
IH never had atool for this .it is only held in by the compression on the oring seal.
I found the best solution on this was to pull it out, I took a bar of steel and put a slight hook on it so i could grag the inside edge, and found something to pry it out, easy peasy....
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2018 John Deere 460E Articulated Dump Truck (A52128)
2018 John Deere...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
