rhmarr1
What are the steps to replace the alternator drive belt on 1991 Ford 555C? Can you take the 4 bolts off the driveshaft pulley, unbolt the hydraulic pump and move it back a bit to slip the belt on? Thanks.
Talked with friend who had 555 and he said following: Unbolt the drive shaft from the pulley (4 bolts) and slide the shaft back so you clear enough for the belt. Do not need to unbolt the pump.
