I'll try to help you OK from beginning. new replacement filter is now full of fuel.
you have opened bleeder on injection pump and got air out of line cranking engine for 10 seconds
then you must loosen the fuel lines on the injectors themselves only 1/2 to a full turn needed with all loosened crank engine over looking at lines you will see air bubbles out of fittings as fuel starts to build the bubbles will turn into a spray tighten lines retry still not starting undue on line my have to have helper if tractor in picture is the one you ran out of fuel with one line loose others tight crack engine over with good spray coming from line tighten line and listen to engine. is trying to run on one cly? if yes open next injector line and repeat. if no! open line again and retry hopes this helps
