Replacement tires for NH 56 Hay Rake
   / Replacement tires for NH 56 Hay Rake #1
Blksim
S.W.Va.
I didn't want to spend too much on replacements. Really wanted used. The wheels are 15" and someone before me had but some old radial car/truck tires on it. They are really too wide. I had heard you can use old volkswagon tires but I haven't run across any of those. I am going to call the ag. tire dealer. Thought maybe someone on here would have suggestions.
   / Replacement tires for NH 56 Hay Rake #2
The rake really needs a ground drive tire. I believe the rim widths are 4", so car tires are a bit wide, but so what? I used a VW Beetle (old Style) tire on my baler for a while until it blew up, but that is a tire that would work on a narrow rim. Both tires need to be the same diameter/radius. Otherwise, one will slip because its a solid axle. If one slips, the rake will drag a bit. I suspect a CUT dealer would have some worn take-offs that would work on your rake. I also have a NH 56 rake. TSC still sells teeth for it for $1.39. They have the tires, too.
   / Replacement tires for NH 56 Hay Rake #3
I'd get used car tires from an auto salvage yard, Snow tires would provide better traction.
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
Miller Bobcat 225G Welder (A49461)
Miller Bobcat 225G...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
Vermeer SC802 (A50322)
Toro Workman Cart (A50322)
Toro Workman Cart...
