Oil & Fuel Replacing a fuel filter *DELETED*
   / Replacing a fuel filter *DELETED* #2
Re: Replacing a fuel filter
If me, I'd replace it with a Deere filter. /forums/images/graemlins/tongue.gif
Thank you for your reply sir. Found the answer in the JD tech manual. It is a self prining system and the the filter/pump is primed by relieving the air back thru subject hose to tank.
Personally I think the Deere filter is quite rinky-dink and find it difficult to justify $8-$9 for a replacement element.
   / Replacing a fuel filter *DELETED* #4
Whatever works.........
But that return line will be mighty important if you run out of diesel and you do not have to bleed the system to get running again (I assume that is why the cheaper filter without the extra line was indeed 'cheaper').
Good to find out what that extra hose is for. /forums/images/graemlins/wink.gif
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
A1 Terminator 3pt Blower w/ 60 Gal Tank (A50120)
A1 Terminator 3pt...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
