Replacing Cessna Valve on 1964 ford 4000
   / Replacing Cessna Valve on 1964 ford 4000 #1
sony224422
1964 Ford 4000 backhoe, 1953 farmall sm 1948 farmall h, 1948 farmall super a
Hello,
I have determined that my relief is either bad or the valve is cracked internally. I think at this point I am ready to just replace it. I am not the best with hydraulics, so I am looking for some advice.
I would need to find something 20-22 gpm 2 spool open center with power beyond, 2000 psi, work port 3/4, pressure in 3/4 and return is 3/4. If I call up with that information would I be getting what I would need?
Thank you!
   / Replacing Cessna Valve on 1964 ford 4000 #2
SurplusCenter and Summit hydraulics are good places to start with. They should have what you need.
It may not be a direct replacement though as the mounting on the new valve is most likely different.
Not sure if you're looking for joystick valves or not but here it is:
Don't forget to get the power beyond sleeve for whatever valve you end up going with.
   / Replacing Cessna Valve on 1964 ford 4000 #3
I highly doubt a Ford 4000 has 22 GPM flow unless someone added a large reservoir and auxilary pump. Might want to confirm pump flow and purchase appropriately sized valve.
Thank you, I will check into them. The mounting is okay, I can make something to work, I know I’ll be either replacing or adapting lines already. Is that enough information, I am confused about the spring detent stuff. I think I want them to center? And both be 4 way?
As far as the pump, yes sir it is a 22gpm pump from the factory. This is an industrial with a 712 loader and 723 backhoe. I flow tested it and got 20 gpm at 1000 psi and 12 gpm at 2100 psi
   / Replacing Cessna Valve on 1964 ford 4000 #5
Sony,
I had one of the Ford 40000 industrials great machines.
There is a guy on yesterday's tractor that knows alot about them. Can't remember his screen name but u can do a search there, I'd imagine he could help alot
   / Replacing Cessna Valve on 1964 ford 4000 #6
You probably need to something with the pump first. Those flow numbers tell me it is worn out
   / Replacing Cessna Valve on 1964 ford 4000 #7
Consider getting a 3 spool valve you might want another function at some point like a grapple.
Thanks everyone. I ended up ordering a valve and power beyond on surplus.
As far as the pump, I took it to a shop and they check it out and said it looked decent. Little worn but should be fine. I can get it to flow at 16 gpm at like 1600 psi, 2000 is the relief pressure but I was using a plug in the relief port for testing. I also wanted to make sure to not blow anything apart too.
Thanks again
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
1997 CATERPILLAR D400E OFF ROAD DUMP (A50458)
1997 CATERPILLAR...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A50397)
2000 John Deere...
2004 International 4300 Truck, VIN # 1HTMMAAMX4H667102 (A48836)
2004 International...
2010 UTILITY 53X102 DRY VAN TRAILER (A50046)
2010 UTILITY...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A50397)
Kubota 24in Quick...
