Replacing hydralic filter
   / Replacing hydralic filter #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I am doing the 50 hr. servvice on my TN75. The hydralic oil filter is located in a very awkward position because of a FEL mounting bracket. There is no more than about 1/4" clearance between the bracket and the filter. The filter is a big sucker and a standard oil filter wrench won't fit it. I'm thinking I'll have to use a strap wrench to get it off. Has anyone experienced this dilemma, and what was your solution?
   / Replacing hydralic filter #2
A strap wrench will work there, but if it is a cabbed unit, the strap wrench is useless for the fuel filter. Most auto parts stores and main line tool trucks sell oil filter pliers made by K-D and marketed under various names. The largest size available works well for all TN fluid filters including the PowerShuttle filter canister. You will find the factory has the filters MEGA tight, you can use a little moderation installing the fresh ones. Watch the engine oil cooler doesn't come loose as you attempt to take the engine oil filter off.
   / Replacing hydralic filter #3
Rick gave me the same GREAT advice.
It's the oil filter that will give you the hardest time. /forums/images/graemlins/blush.gif
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2010 Caterpillar 304C CB Mini Excavator (A56857)
2010 Caterpillar...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
2013 Ford E-Series Cargo Van, VIN: 1FTNE1EW5DDA01380, Gas Engine, Automatic Transmission, GVWR: (A59076)
2013 Ford E-Series...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
