Replacing Kohler Command in PT 425
   / Replacing Kohler Command in PT 425 #1
cherylspt
La Grande Oregon
2003 Power Trac 425
Although I have been looking at this forum for the past 10 years I have not posted I live right down the road from the (carpenter) and that is why i purchased the Power Trac. I now am approaching a 1000 hours of use and abuse. Have moved tons of large rocks to form rock wall behind the house, mowed about 5 acres of the property and used the PT for all of the landscaping. I loaned it out several times and on one occasion it was run low on oil. I am now experiencing a lot of blow-by and if I work it hard it will go through oil in under an hour. Will probably replace with a Kohler. called PT and they suggested I purchase closer to home. The only thing I am not sure of is the shaft size 1 1/8 or 1 7/16. Engine model CH25S Spec. Number 68500 serial #3024103751. Tractor purchased for me but quickly became my wife's tractor. Appreciate any input. cherylspt
   / Replacing Kohler Command in PT 425 #2
Welcome to TBN!
You might want to give Jack's small engines a call. They are reportedly very helpful.
   / Replacing Kohler Command in PT 425 #3
   / Replacing Kohler Command in PT 425 #5
When in doubt, go with the larger one... you'd only have to replace the love joy style coupler if you choose wrong. I believe PT machines a coupler that fits the 1 7/8" shaft. (At least that's what I recall since I got mine through them.)
   / Replacing Kohler Command in PT 425 #6
These are the only shaft sizes that I saw on the horizontal Kohler engines,
1 in
1 1/8
1 1/4
1 7/16
   / Replacing Kohler Command in PT 425 #7
JJ,
I went back and checked what my replacement Robin shaft size was, and it was 1 7/16" (vs 1 7/8"). So to correct my previous statement, "PT machines a coupler that fits the 1 7/16" shaft". :) It was $40 or so.
I really appreciate all of the advice. Wondering if Pajoub's PT was a 2001-2003 model. If so then it is quite possible that mine is the 1 7/16 shaft. Will probably call Jack's and the Small E Engine Warehouse to compare cost. I would be willing to pay more for the EFI model if it would work. Believe me I will do whatever is necessary to keep this machine running. My wife looks at it as indispensable. It allows her to do a lot of landscaping work that she would normally be unable to perform.
   / Replacing Kohler Command in PT 425 #10
= Wondering if Pajoub's PT was a 2001-2003 model. If so then it is quite possible that mine is the 1 7/16 shaft.
According to Pajoub's signature block on the above referenced post, he has a 2003 PT-425. PM him at that link, maybe he will respond.
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
100GAL L SHAPED FUEL TANK (A50854)
100GAL L SHAPED...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
