replacing o rings between control valve sections deutz
   / replacing o rings between control valve sections deutz #1
tranman
pittsfield pa
deutz 6260f
In addition to the o rings there are small rubber discs that are distorted from pressure. they look like all they do is block a hole. Any ideas?
   / replacing o rings between control valve sections deutz #2
I am not sure, but was thinking of disassembling mine as my valves are weeping. Would be really nice if it stayed dry. Let me know if you find out anything. I wont be where my tractor is until middle of April.
LNK
   / replacing o rings between control valve sections deutz #3
All I remember about those valves (depending on what brand you have) there's "special" 0 rings in them. They are NOT a std. 0 ring, as I remember the Deutz ones, have a flat side on the 0 ring.
It's been years since I've had one apart, but I remember having to get the 0 rings from my Deutz dealer, as they are spl...
I think you can still buy them from Peter, at 231 924 3420
SR
   / replacing o rings between control valve sections deutz #4
Thanks, I will probably purchase a couple sets just to have also. What is the name of the dealer so don't look like a complete fool when I call?
Larry
SR, Thank you for the information. I found some metric o rings and put it together, It's OK doesn't leak. One section has a roll pin in a blind hole which is open to an oil passage. It must have an o ring to seal it off.
Thanks again Tranman
2016 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2016 CANYCOM SC75...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2021 FORD TRANSIT 250 CARGO VAN (A53426)
2021 FORD TRANSIT...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
