beowulf
Veteran Member
- Joined
- Dec 31, 2003
- Messages
- 1,186
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
We have an insert in our fireplace. It is one with a glass door, a fan (we put on a rheostat control), and is all sealed up neatly into the fireplace opening. We burn wood maybe a maximum of 30-40 days a year - sometimes much less than that depending on the weather. We live on 90 acres so have a never ending supply of wood stacked in a shed and sometimes burn wood left over from ranch projects.
We have had a chimney sweep guy clean it perhaps 3 times over 20 years - then the guy disappeared - perhaps he is stuck in a chimney somewhere.
I am concerned about creosote build up and a risk of fire. I am considering retrofitting it all with a double wall metal pipe. I think the opening on the top of the insert is 6 to 8 inches. From the top of the insert to the top of the chimney is, I estimate, about 20'. I think I could drop the pipe from the top down and have it rest on the opening. Once this is done, I should be able to clean the pipe myself with the correct diameter brush and extension handles for that - the debris would hopefully fall into the insert and then could be removed from there.
The problems I see are: 1) removing the damper (I have no idea what that will involve but I don't think it will be a lot of fun), and 2) trying to drop in the new pipe and have it line up with the insert - there will be no ability to do much other than drop it in using a trouble light inside the pipe to try to line it up - as once the insert is into the fireplace opening it is totally sealed up. Thee is also the issue of attaching the several sections of the pipe - one by one - without dropping them down the chimney. I think I can manage that with some help - and a home-built clamp of some kind. I would also have to match up the lengths of the pipe sections to have it finish up even with the top of the chimney - will have a spark arrester cover there. I know this will not be easy and I will run into problems I have not thought of.
Anyway, my question is how doable is this? Are there easier ways or options I have not considered? and what am I in for in removing the damper? All help is appreciated.
