TractorDale
Got my 6' BB delivered today from TSC-brand is "Farm Force", thought I was getting KK but it seems basically the same. The problem is the way in which the lift bracing was bolted together made the lift pins too wide for the arms on my TC29. So I struggled to get the big bolts loose and rebuild it to make the pins more 'standard'. Still had difficulty with the lift arms-tires get in the way even though I've got extendable arms. So I took the lift pins out and reversed them so they are inside the frame. Got everything hooked up and seems to work ok. Is this kosher?
Related is the HF quick hitch that so far is not helping even though I used a jack to widen the lift arms-they were too narrow( top pin is the problem now and plan on welding up some fix)
Thanks for your thoughts.
Dale
Dale
