Reviving three "dead" lithium drill batteries- here's how I did it
   / Reviving three "dead" lithium drill batteries- here's how I did it #1
KYErik
Platinum Member
South central IL
1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
Short version-
Taking proper safety precautions and anticipating a possible explosion, I used a 12 volt "dumb" charger to raise the voltage of three dead/non-chargeable 18-20 volt lithium drill batteries up to 3-4 volts, then placed them on the factory charger. Then the factory charger worked normally for all three batteries and there was no explosion.
Long version-
I had three lithium batteries that my chargers stopped working on over the last several years. 2 of them were 20 volt craftsman batts and 1 was an 18 volt hitachi. All three were at least 8 years old and had likely been sitting idle for at least 12 months when I noticed the problem (the factory charger would not charge them). Since then, they have been sitting for at least 1 year.
For the craftsman batteries, the charger did not light up or recognize them as attached- one had 0.1 volt, the other had 0.3 volts. For the hitachi battery, the charger showed it as fully charged while a voltmeter said it had only 0.2 volts.
From what I understand, lithium chargers must sense a small voltage before they will recognize/charge the battery- it seems like the cutoff is somewhere around 3-4 volts. So, you have to "wake up" the battery and get it above 3-4 volts. I used a "dumb" 12 volt battery charger set to 2 amps- this provided about 13 volts when attached to the drill battery. Knowing that lithium batteries can explode, to minimize property damage and the risk of personal injury I used a long extension cord and placed the battery in a 5 gallon bucket. I had 18 gauge wires stuck into the positive and negative terminals of the battery and then attached the charger's alligator clips to those wires.
Attached is a pic of the voltage when I began.
I plugged the extension cord in (from a safe distance) momentarily, then gradually worked my way up more and more seconds. The voltage would slowly drop after I unplugged the charger. Eventually after 5-6 minutes of plugging it in and unplugging it, the battery remained at about 4 volts even after the voltage dropped for a few seconds. The battery did not ever feel warm to the touch. I then plugged it into the factory charger- and the charger recognized it! This method worked for all three batteries! I am running the hitachi battery down right now in a work light and the capacity seems to be similar to battery that had never malfunctioned (I have 6 of these batteries and a variety of tools).
   / Reviving three "dead" lithium drill batteries- here's how I did it #3
Thanks for the info.
   / Reviving three "dead" lithium drill batteries- here's how I did it #4
99 times out of 100, this will work safely.
The reason they take such precautions in charging lithium based batteries, is the risk of "runaway". This happens when the resistance across a cell peaks in a small portion and localizes heat. This "hot spot" will trigger a runaway reaction throughout the cell, and cause meltdown or (worst case) explosion.
I would've done the same thing... except one part:
Next time, use a metal bucket. The meltdown temp of a runaway lithium could catch your plastic bucket on fire, faster than you could grab an extinguisher.
   / Reviving three "dead" lithium drill batteries- here's how I did it #5
I tried a similar thing with my NiCad Craftsman 19.2V batteries. I have an automatic charger that'll do 2-10 amps with a desulfate cycle and trickle charge once full (along with voltage and battery % readouts). It worked for a while, but eventually they didn't hold a charge and I upgraded to DeWalt 20V lithium. Hopefully they respond better than NiCad.
   / Reviving three "dead" lithium drill batteries- here's how I did it #6
Risking your Harbor Freight meter there..... :laughing:
Good explanation. Thanks. :thumbsup:
Brouwer Hitch-Hiker 3600-R Piggyback Forklift (A44571)
Brouwer...
2013 Chevrolet Impala Sedan (A44572)
2013 Chevrolet...
Towable Light Tower (A44571)
Towable Light...
2014 Ford Explorer AWD Sedan (A44572)
2014 Ford Explorer...
More info coming soon! (A44572)
More info coming...
2018 Ford F-550 4x4 18ft Rollback Tow Truck (A44571)
2018 Ford F-550...
