REZLOH CUTTING EDGE
   / REZLOH CUTTING EDGE #1
VIEWQUEST
Bronze Member
Anyone have experience or knowledge bolting on a Rezloh cutting edge on a New Holland bucket for an 18LA loader or is this cutting edge only available for industrial equipment?
   / REZLOH CUTTING EDGE #2
Yes I've got one on my bucket. I like it so well that I had it welded on /forums/images/graemlins/cool.gif I've used it for digging in rock dirt(more rocks than dirt), moveing logs and other brushy junk and it works great. The edge came in two plates that can be bolted to the front edge. It is made of heavy HARD metal and mine has shown very little wear. It is also very usefull to drop the bucket edge straight down and use it as a rake - getting branchs out of grass and smoothing gravel.
The only disadvantage is in breaking thru new ground - a regular tooth edge will have the teeth widely spaces and they will be longer. But once the surface is broken, I believe I have the advantage in the amount of dirt I can dig and move. Also, depending on how it is mounted, you can gain quite a few inches on the length of the bucket bottom.
I think you would like having it. /forums/images/graemlins/grin.gif
   / REZLOH CUTTING EDGE #3
I purchased a Rezloh edge for a 6' HD Kubota bucket in hopes of making it useful. I ended up wasting my money on it because I don't use it at all. This does not mean that the "Rezloh" is not a good product. I have "Loader Buddy" on my FEL and wouldn't want to change because of it's versatility. I even have a grapple that sits idle because of the same reason. I work in the woods,
with rocks, roots, stumps, scrap metal, fencing, garden, driveways etc. and the list goes on. Would not be w/o it. For me, one bucket does it all!!
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2017 John Deere 6120E 120HP 4WD Agricultural Tractor (A50322)
2017 John Deere...
