Ridge Vents
   / Ridge Vents #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I'm gonna get a new roof this spring and was wondering what the consensus was on the best/most efficient ridge vents to request? Our house is fairly new, 13 yr old, and has them. No idea what brand or where they came from.
You always get to pick the shingles and sometimes underlayment but ridge vents are never talked about. So I decided to educate myself and found a dizzying variations of them. So now I'm seeking your opinion.
#1- we live in northern Wisc that affected by lake effect snow.... which is code for lots.
#2- winter temps can swing from -20 to +30 in a week to 10 days
Your thoughts??
   / Ridge Vents #2
Your house is not that old...do you need to replace the ridge vent? If so the best I can tell you is that they are all the same...piece of plastic that completes the airflow from your soffits. Now you being Hayward (not far from here), are you looking at steel roofing or just conventional shingles?
   / Ridge Vents #3
While we are more north but do see our fair share of snow we find ridge vents not to be the vent of choice.
The choice vent here is 'Maxivent' which is a 12" X 12" Cupola style with louvers on all 4 faces. They offer a few options and each are rated for attic sizes.They stand about 2 ft tall and come in popular colors. Insulated and adjustable for roof pitches.
The design works no matter which direction the winds come from and have proven themselves.
In heavier snows ridge vents get buried and become inefective. Rotating vents usually freeze up when most needed leaving the Cupola as the preferred option.
Attractive enough and fairly priced at about the $100/ range.
   / Ridge Vents #4
Never seen that as an option around here. Code on new construction around here only calls for the ridge vent...in snow-load areas the roof pitch is high enough that I've never seen anybody burying the ridge vent...even insulated to R50 there is enough heat/air to keep that clean I think.
   / Ridge Vents #5
Our ranch style had soffit and gable vents only for the first 35+ years and then converted to ridge vents when reshingled about 5 years ago. (Still have the soffit and gable vents) Had a mother of all hailstorms a year ago last labor day and will be replacing shingles again this summer.
The adjustor mentioned that all the shingles on the north slope show blistering and attributed it to inadequate ventilation. Not sure why just on the North slope though. (north central Kansas)
Current shingles are Malarky Class 5 (50 year) asphalt shingles. Probably will go with the conventional metal box vents this time around.
   / Ridge Vents
Sorry, just conventional shingles.
If you start researching ridge vents you'll see that there's a bunch of them to choose from. My concern though, is the roofers will install the most economical or easily procured ( say middle of the road) and not the best available. You can ask 100 people and 95 will have no idea of what brand/style they have, let alone what they do. That's why I decided to educate my self on this. If I don't know whats best I can't ask for the best.
The problem I'm seeing is none of the manufactures break down there products by region/zone like the nursery's do for plants. What may work great in Tenn may be a disaster in the far north.
   / Ridge Vents #7
The problem with ridge vents is that almost all of them are way too small. I need about 3 inches of space at the bottom of the roof, but most ridge vents give you less than 1 1/2 inches at the top. So, how can you vent properly if the "inlet" vents at the bottom of the roof are twice as big as the ridge vents at the top?
   / Ridge Vents #8
I used power vents on my house for that reason.
   / Ridge Vents
My house has at least 3.5 to 4" cut back in roof sheeting on each side of peak so I'm sure I've got plenty to work with.
   / Ridge Vents #10
Usually the roofer will ask you what shingles you want and give you a bid on the total job using the materials they use most of the time. When I hire a roofer, I specify that I want the roof stripped down to the decking and the wood inspected. If any needs replacing, add that to the cost of the job. I want all the flashing and vents removed and new ones installed. I want 30 pound paper and Grace Weathershield used in the valleys. I want 1 1/2 inch nails to be used. No staples EVER!!!! And I want a brand new ridge vent installed.
I've seen several different brands of ridge vents and think they are pretty much interchangeable as long as it's a name brand that I'm familiar with. They usually come with their own nails, but if not, I make sure they use the proper sized nails. In every case, they already know this and it's just a formality that I bring it up.
The advantage of a full ridge vent is that it gives you the most air flow under your roof. Other types of vents direct the air coming into your attic from your soffit vents to just those areas and the flow of air is not uniform. The wider the area, the more of the underside of the roof that you get air to flow, the dryer your attic will remain. Venting is not for cooling, it is for removing moisture created by condensation. If you cool it, that's a bonus to a small degree, but the ultimate goal for venting the attic is to make sure that the moisture left on the rafters every morning when the temps warm up is removed.
71058 (A49346)
71058 (A49346)
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
TRAIL MASTER...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
