Riding mower about caught on fire
   / Riding mower about caught on fire #1
buckeyefarmer
Epic Contributor
MD
Kubota L3940 L5030 MF205-4 BX23
Bearings went out on an idler pulley on the deck. It's a sealed unit with no grease jerks. It had been making some noise, but I hadn't taken the deck off to check yet. I was mowing after dark, and it threw the belt off. I put it in the barn, then noticed the smoke coming from the deck, so I pushed it back outside and hosed it down. There was dry grass on top of the deck and the heat had it smoldering.
   / Riding mower about caught on fire #2
put water on it and then change the idler when its cool enough
   / Riding mower about caught on fire #3
Good point about the dried grass on the deck! Glad you caught it.
   / Riding mower about caught on fire #6
I got the part ordered. dealer said 2 days.
When it started making noises I did stop and remove the belt cover on that side, and did pull a bunch of grass out from around the outside spindle, but couldnt see any issues. I also lifted the mower and cleaned out under the deck, thinking that might be the issue. to clean the middle of the top, the deck needs to be removed, which is a pain. Fortunately I recently bought a mower lift at TSC, which works great.
   / Riding mower about caught on fire #8
If you have sealed bearing unit, you can extend their life by drilling a hole in the shaft housing and screwing in a grease zirk. Pump in a few pumps of grease every time you sharpen the blades. They will still go bad eventually but doing this will extend their lifespan.
   / Riding mower about caught on fire #9
I put my zero turn away last year and as I was closing the door I smelled burning grass. I looked and the grass was burning under the engine and spreading to the deck. I pulled around by the hose and doused it, then sprayed it off. I learned my lesson, now I pull it outside the building and blow it off with the air hose before putting it away.
   / Riding mower about caught on fire #10
i blow my mower decks off and hte engine too after mowing. keeps stuff away from holding water too.. that preents rust.. also lets you see oil leaks if any are present.
   / Riding mower about caught on fire #11
FWIW, I've found an electric leaf blower more effective in cleaning decks than a compressor air hose.
It's very good for blowing the grass off the big Bush Hog.
   / Riding mower about caught on fire #12
speaking of electric leaf blowers. anyone ever use one to 'power' a forced fresh air helmet / suit for painting around less friendly chemicals?
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
John Deere 5105M (A53317)
John Deere 5105M...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2019 CATERPILLAR 320 GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2013 Ford Taurus Sedan (A59231)
2013 Ford Taurus...
