Ring around the trees
   / Ring around the trees #1
barrentine
I live in central Georgia and i have a couple of sawtooth and water oaks that i planted about 12 years ago.About mid summer the grass forms a ring about 20' around these oaks where it looks like the grass is not near as thick as everywhere else.what is this.
   / Ring around the trees #2
Look up fairy rings on google. Or its the trees drawing nutrients & moisture from the lawn. Fertilize & water these circle areas. If the circle has an outer darker green ring - its most likely a fairy ring. I get them - they come/go with the seasons.
   / Ring around the trees #3
Not sure about a "ring", but the large trees in my lawn (beeches and oaks) have a full circle around the trunk, roughly the size of the canopy, where the grass never does well. Pretty sure it's from the tree roots drawing in all the available moisture and nutrients.
If it's a ring, is it aligned with the tree's drip line by chance? If not, and if it grows outward with time, it's probably a fairy ring (fungus). May have been brought in with the trees and is slowly growing outward. A lawn fungicide should take care of it. Lawn fungus is common in the south, especially in humid areas and/or where grass is allowed to grow high.
   / Ring around the trees #4
I agree that the thinness of the grass is likely due to the trees denying the grass of water and nutrients. Also, some grasses are less shade tolerant than others, so the trees may also be denying sunlight to your grass.
Steve
   / Ring around the trees #5
When is the best time to plant a tree for shade. Answer : about 30 years ago ....
Instead of trying to grow grass... grow the tree. Place a layer of mulch in the circle formed by the canopy. Trees in a lawn are starving. They 're competing with the grass for water and nutrients. Trees in a forest grow in natural mulch. I value my trees for shade more than grass. After all, Your Oaks took 12 years to grow.
PS .... Don't mound the mulch against the tree's root flare. Many commercial landscapers do it... but it's WRONG. You don't want anything to shelter bugs and fungus against your trees.
   / Ring around the trees #7
He probably isn't. They are pretty easy to recognize. MY single ring looks like those in your link.
Hosspuller - I found that either I don't have the right type of mulch(chipped pine trees) or do something wrong. My "mulch" attracts many types of bugs this time of year. It could be that the mulch is damp. Believe me, its the only damp thing around here this time of year - at least until the fall rains.
   / Ring around the trees #8
A few kinds of trees emit toxic chemicals that harm some other kinds of plants. Black walnuts are famous for this--tomatoes don't do well around walnuts. The effect is called allelopathy. Some kinds of grasses won't grow under some kinds of oaks. Here's a link:
Oak Trees Allelopathic?
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
