Ripper, subsoiler
   / Ripper, subsoiler #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
Whats the thickness of steal plate used for a subsoiler shank? I thought of making one. It would be for a 28 hp, 2500/3000# tractor.
   / Ripper, subsoiler #2
I just built a potato hoe/subsolier for my Kubota B7100. I welded up the shank using 2" x 1/4" sq. tubing. For the blade part I used 1/4" plate, 10" x 10" shaped like a triangle. I hang (2) suitcase weights on it & it will dig so the drawbar is resting on the ground. It's all my tractor will handle. Might order the proper blade from Agri Supply, they are fairly cheap.
   / Ripper, subsoiler
The square tubing takes the strain well? I was thinking it would be something like a 7/8 inch or an inch plate. If it works on yours I can probably do something similar. If its for potatoes I'm guessing the ground has been regularly worked? Hows the weather in new brunswick these days.
   / Ripper, subsoiler #5
Here is a set of plans for a subsoiler from Lincoln Electric's web site. It has three rippers but the plans can be modified.
Sub-Soil Ripper
   / Ripper, subsoiler #6
I used 1"x 4" steel and it has held up well
   / Ripper, subsoiler
Thanks for the replies. I will get a chance to pic up the steel next week. I'm not sure as to make it one fixed shank, or a few adjustable. Thanks again for the responses.
   / Ripper, subsoiler #8
1 inch thick is common. Be sure to V the leading edge. If designed properly the beam can be reversed after it is wore in the front. The Fred Cain Subsoiler is designed like that. Ken Sweet
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
66'' root grapple (A53421)
66'' root grapple...
2012 Club Car Electric Cart (A53424)
2012 Club Car...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Quick Attach EZ Axe Skid Steer Tree Shear (A53473)
Quick Attach EZ...
