RK24 bogging down.
   / RK24 bogging down. #1
Ohio RK24
Bronze Member
2019 RK24
RK24 Boggs down and almost dies under full throttle, occurs wether doing work or just moving tractor around on flat ground.
No abnormal noise or behavior other than that, I can move around at lower throttle without problem when trying to do anything that requires higher throttle, it Boggs down, let up on the treadle and it seems ok.
I just purchased both fuel and water separator filters, some new diesel fuel, water disperser/tank cleaner plus fuel injector cleaner.
   / RK24 bogging down. #2
RK24 Boggs down and almost dies under full throttle, occurs whether doing work or just moving tractor around on flat ground.
Do you buy off-road diesel or fresh diesel at a truck stop? Avoid off-road diesel as the station under ground tanks might be refilled once a year.
If you suspect bad diesel with microbes and a dark color to it, yes, change out the filters, the hose to the filter and flush the fuel tank.
Seamfoam or Gumout products work better than the typical fuel treatments out there. In fact Seafoam's original use is for diesel fuel systems.
The Yanmar engines have no issues with Seafoam. In fact, the Yanmar diesels in Deere machines for the past 45+ years are still going strong.
Yanmar makes these same engines for their Marine division. Seafoam got it's name from the Marine diesel industry as the go to source for cleaning the both the fuel and oil system. (y)
2006 Chevy Trailblazer (A47384)
2006 Chevy...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51243)
2024 INGERSOLL...
2002 International 4400 SBA 4x2 Flatbed Truck (A49461)
2002 International...
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
