rock shaft adjustment arm hard to move , 4310 e power reverser
   / rock shaft adjustment arm hard to move , 4310 e power reverser #1
dpoole
marietta s.c.
jd 4310 , jd 750
the rock shaft control handle is very hard to move up or down , some one told me it could be friction washers causing the problem , also a fault code is showing and the dealer said it was the clutch switch , can someone tell me where it is located and how much trouble it is to change
thanks
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 GENIE GS-3246 (A53843)
2016 GENIE GS-3246...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
