Roller pump 4/6/8 and type?
   / Roller pump 4/6/8 and type? #1
2manyrocks
Super Member
My plain cast iron roller pump is leaking to the point that I think I need a new pump to spray glyphospate herbicide on Kudzu again. I see pump prices starting at about $100 that go up pretty quickly depending on the number of rollers and seals and whether its a silver or whatever type roller pump.
So where's a good place to buy a pump and does it make a big difference how many rollers? If I were to flush the pump after use, would it make that big a difference between buying a cast iron pump versus the other types?
   / Roller pump 4/6/8 and type? #2
To answer your question.
The things that are needed to know are the boom width.
The gallons to the acre.
the pressure needed.
To rinse a roller pump after every use, Mandatory!!!!
   / Roller pump 4/6/8 and type? #3
Thoroughly flushing with clean water is necessary, but even that will not prevent the cast iron ones from corroding and seizing. I had some experience with two of the Hypro 6 roller pumps. However, after rinsing, if you fill it with antifreeze or oil and plug or cap the inlet and outlet, it will not corrode and seize.
I was mainly interested in the more general answer of why (if?) 8 rollers is better than 4 and whether the coatings really made enough of a difference to pay the extra $200 or whatever compared to a plain cast iron pump.
I think whatever pump I have now is just the basic cast iron cheap pump. It was used when I got it, and I've rebuilt it twice already. There's no pressure gauge on my system.
   / Roller pump 4/6/8 and type? #5
I store my pump with diesel fuel in it, keeps it all lubricated inside.
   / Roller pump 4/6/8 and type? #6
Have you read the comparisons on the Hypro Roller Pump website. There's differences in gallons per minute discharge, slight differences in the maximum rated rpm, and differences in pressure, but I don't know whether the differences in the cast iron, Ni-Resist, and SilverCast are worth the difference in cost or not.
   / Roller pump 4/6/8 and type? #7
The 8 roller would be more volumne as well as pressure and would be used on larger booms like 40 foot. A four roller is for 20 foot! Without rinsing just buy the cheap pump. Other wise soaking in oil out of season of use is great and a little wd-40 after rinsing between short term use sure does increase the life.
Thanks for the tips. Had our kudzu knocked down, but now it's come back pretty bad so I need to get another pump.
   / Roller pump 4/6/8 and type? #9
What about a rebuild kit for the old one?
I had trouble finding a rebuild kit for the old one and ended up using grease seals. So they didn't last long.
I ended up buying a new silver pump, but haven't used it yet.
   / Roller pump 4/6/8 and type? #11
The 8 roller pump will give you a more constant steady pressure than the 4 roller. You won't have the pressure spikes which will give you a more even flow rate. I only use the 8 roller pumps but I usually pick them up out of someones scrap pile and rebuild them. I always flush with water after using and like to flow some vegetable oil thru them ot keep them lubricated if they will be sitting for very long. When you take a pump apart you can see the rollers in the lobes and the close tolerances, doesn't take much rust to cause them to stick.
For your application you could probably pick a rebuild kit up and rework your pump and it should take care of your needs.
Thanks for the veggie oil tip. I do that with my plow to keep it from rusting.
ended up buying the 4 roller pump silver series for roundup use. Works better than what I was using that had more rollers, but probably was worn out. Also made sure to flush and run veggie oil through it when I was done. Thanks again for the tip .
   / Roller pump 4/6/8 and type? #14
What do you think about using a little used Hytrans or Gear lube
   / Roller pump 4/6/8 and type? #16
Thanks, I ended up with a Fimco three point (LG-55-3PT) and a cheap (Hypro Cast Iron 4-Roller Pump) 4 roller pump. HOpefully I can manage to keep it operating for a couple of years.
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2020 DRAGON ESP...
2015 Chevrolet Tahoe SUV (A59231)
2015 Chevrolet...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
