orlo
Platinum Member
Hi:
Does anyone know if JD or anyone else publishes 'safe' operating side angles for different JD tractors? I know they are all ISO xxxx compliant but I can't see the specs for that anywhere. I suspect most of that standard has to do with the rops anyway which I'm looking to avoid needing
I realize it would also change due to factors such as tire loading, tire size, a low implement, any top weight (awning, etc.) but I'm looking for a general guideline as to when the tractors (2305 and 3320 in particular) will roll over. Most small lawn tractors come with a 'safe' degree rating. I'm just looking for the same (A degree limit or %grade limit) to check some slopes I have to see if they are side mowable.
Thanks,
Thanks,
