rollover plow
/ rollover plow #1
harley152
OK, I have a lead on a JD 3 bottom rollover plow "needs work" and I have a 50 hp tractor. I have a 6' tiller but think that plowing first and waiting a couple weeks before tilling would work much better for my organic food plot than tilling two or three times to break up the sod prior to planting. Am I wacko or on the right path???
Jerry
/ rollover plow #2
Jerry
50 HP will handle a 3-bottom plow in most cases. A 3-bottom rollover plow ISN'T most cases. As far as weight, you're dealing with 6 bottoms, albiet shorter coupled, but a typical 50 hp tractor will struggle with a 3-bottom 2-way plow to lift it. Also, that added weight means a struggle to hold it to operating depth when it's in the ground. It takes a stout tractor and a few front end weights to handle that plow.
Yes, plowing sod before tilling is a GOOD idea though, just MAYBE not with that plow.
High Hood All Aluminum Timpte 720 Trailer (A63118)
High Hood All...
(6) SALT BLOCK HOLDER (A62131)
(6) SALT BLOCK...
2018 Subaru Outback AWD SUV (A61569)
2018 Subaru...
2016 John Deere 1775NT Planter (A63109)
2016 John Deere...
New/Unused Landhonor Mini Skid Steer Rock Grapple (A61166)
New/Unused...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
