Rollover reducing implements
   / Rollover reducing implements #1
louiedog
Shacklefords, Virginia
JD 302
Hello,
I recently bought a 1983 JD302 Tractor/Loader and was looking for an implement to put on the 3-point hitch to skid logs. This is my first tractor and have been told I need to have arear attachment to reduce rollover. The tractor has ROPs and a seat belt but, I would prefer not to put them to use. Any help will be appreciated.
   / Rollover reducing implements #2
They are called log archs.Picks up the butt end of the log.
   / Rollover reducing implements #3
Read some notes on the web about towing with tractors.
Apparently it is important where you hitch the load. It must be hitched below the axle, for example to the middle drawbar. Hitching the load high is supposed to cause the tractor to do very dangerous wheelies.
The tow behind Arch would have the benefit of picking up the end of the log to reduce friction, and still could be towed behind the tractor attaching at a safe place for pulling.
It won't necessarily keep you from rolling sideways, although it might provide a little buffer between the log and the tractor.
   / Rollover reducing implements #4
The most important factor in Roll Over Prevention, is knowledge. Knowing your equipment and all the safety factors before use, is a must. I would suggest you look for training and/or reading materials from state or county extension offices or contact the local 4-H offices. Seek out as much information about the equipment you buy, or are shopping for, from the manufacturers or on the net. Educating yourself is step one to years of safe and enjoyable operation. :)
   / Rollover reducing implements #6
So what's the plan ?, jump clear just before it goes over ?
Keep your will up to date.
Sorry I was not clear. I use the seatbelt. What I meant was I hope the seatbelt and ROPs will never have to save me.
   / Rollover reducing implements #8
That is like me. I always wear my dirt bike helmet, but I have only "used" it one time. One might think that hearing gravel and shale scraping against a helmet that you are wearing would be an awlful sound. In my case, (when I finally came to a stop, and looked at the damage to my helmet), I realized what a pleasent noise it truely was. :)
   / Rollover reducing implements #10
Lets not be so tentative about this ?
NEVER tow from the 3 pt and especially not the top link attachment point.
From the ROPS - again, NEVER.
The very low gearing and incredible grip that that tractors have just about ENSURE that they will flip over backwards if you attempt to tow a load that provides enough resistance above the rear axle center.
The correct term for this is that the tractor "rotates about its rear axle".
To the O/P;
The log arch is primarily to prevent the end of your logs from digging into the ground if/when you go into a dip and then climb out.
You want to carry anything/everything as low as possible for stability, but if the butt end of a tree is being carried on the 3 pt and is too close to the ground it can dig in when at the bottom of a dip in the trail. It is then POSSIBLE for it to pivot up and over you - depends on the size of the tree, e.g. a 140 ft pine won't flip over the top of a little 25 HP yard tractor (-:
I have some general concerns about you being new to tractors and wanting to skid logs as a first or early project.
DO READ UP generally on logging with tractors, snaking tree lengths through the woods is kinda tricky to put it mildly.
Down grades can kill you if the tree starts to push the tractor. If you have any serious down grades you would be better off with a Farmi winch (or similar). You can DROP that as an emergency brake if you have to, wheeled log arches just keep on coming at you.
Farmi used to have a lot of good general forestry tips on their web site, not "training" per se, but informative.
You would be MUCH better off with a Farmi winch ANYWAY !
Dragging is orders of magnitude more risky than winching.
Not cheap, but injuries are SO much MORE expen$ive.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
John Deere 1775 NT Exact Emerge 24 Row Corn Planter (A52349)
John Deere 1775 NT...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
