Grading Rotary cutter blade sharpen & balance
   / Rotary cutter blade sharpen & balance #1
DMF
Platinum Member
Mass
Massey Ferguson 1552 Cab Model
What is the best way to sharpen and balance rotary-cutter blades. I have touched up the edge with an angle grinder and then just weighed the blades to be sure they were reasonably close. Is this acceptable or is there a better way?
   / Rotary cutter blade sharpen & balance #2
Sounds like a good plan to me. I don't weigh them, as I don't think the way they work that it is that critical, but then I don't grind a lot off each one either. I never remove them from the cutter, just grind in place. Just my way.
   / Rotary cutter blade sharpen & balance #3
I balance the lawnmower blade after sharpening because the driveshaft is also the engine crankshaft. On a brush hog, weighing should be more than enough, I wouldn't even do that unless a major amount of metal came off OR I noticed excessive abnormal vibration.
   / Rotary cutter blade sharpen & balance #4
I take mine off and sharpen them on a bench grinder. After they are sharp, I continue to remove material from either side until each blade balances when the mounting hole is centered on a triangular piece of wood.
   / Rotary cutter blade sharpen & balance #5
This had just been discussed at some length in Parts/Repairs.
Here's the link: Bush hog blade sharpener device.
Most (myself inlcluded) seem to favor raising the brush hog on its side using your FEL, or to some extent your 3 point hitch if you don't have a FEL, and then sharpening the blades in place using a hand grinder.
...Tony
   / Rotary cutter blade sharpen & balance #6
Yep I use a 4in grinder 60 grit disk, never take them off.
I do a good job of making the same amount of pass's
on both sides...close enough fur me!
Gene
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2014 Ag Spray Schaben Sidedresser (A52128)
2014 Ag Spray...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
