Rotary Cutter Identification???
/ Rotary Cutter Identification??? #1
tech141
Bronze Member
Belleville, IL.... for now. 60 acres just South o
JD 2020 with FEL
Looking at buying this 6' Rotary Cutter....
The seller says he thinks it's a Howse, but I'm skeptical. The Green paint is cover up and it looks like the original color is Yellow.
The Identaplate is gone and all/any identifying/informational stickers are missing as well.
Anyone have a guess as to what Make of mower this is?
/ Rotary Cutter Identification??? #2
it does not look like any howse I've seen.
JD uses gearbox covers on some mowers.. but.. I'm not up on JD equipment.
I know servis(rhino) had yellow equipment. some industrial JD was yellow too.
good luck on the ID.. it's not a model i'm familiar with. resembles my servis.. but ... i'm not up on servis models..
soundguy
/ Rotary Cutter Identification??? #3
I have a Howes and it isnt built anything like that. I thought mine was beat up from all the rocks I hit, but that one is worse than mine. Looks really super light duty.
/ Rotary Cutter Identification??? #4
Agree it could be an old Servis,but by that tailwheel design and it being yellow it could also be an old Woods hog.
Boone
/ Rotary Cutter Identification??? #5
There are probably other TBN members that are more knowledgeable than I am in regards to this matter. But it is my opinion that it is somewhat homemade, utilizing different parts from other cutters. The tail wheel assembly appears fabricated and the side bands most definitely appear to be fabricated and installed. I couldn't actually see the side and front bands that well. Perhaps the mowing deck from one manufacturer and a gearbox added from another? Possibility?????:tractor:
/ Rotary Cutter Identification??? #9
How are you doing bullbreaker?
Been doing real good,big thanks for the asking !
Wishing you and your family (all TBN-ers included) great health and big blessings.
Boone
/ Rotary Cutter Identification??? #10
Boone
Thank you. Best wishes for you and your Family--bullbreaker. I also sincerely hope that everyone that is a member of TBN stays safe and warm this winter. And that comes from the very bottom of my Heart and Soul.
/ Rotary Cutter Identification??? #11
Though not exactly the same heres pic of old Woods hog.
Don't know mdl # !
You can see sides been reinforced.
Boone
Boone, Except for the paint, that looks like a definite match to what I have. I figure (as close as I can...) that mine is an old Woods Dakota 72. At least, that's the closest model I can find pics of that matches mine. What is the model of the cutter in your pic?
Mine is almost 100% except there is NO chain curtain on the front to keep debris from flying at the tractor (and ME on it) during operation. I see that the OEM(?) chain curtains sell for near $200.00, but am hoping to build something as good for less $$. Any ideas? I have a few myself but would like to hear from the folks here before stating what I'm thinking.
EDIT: Since I'm pretty new to the game and not great with the terminology yet, thought I'd add a pic of the chain barrier that my cutter is missing.
image.aspx
/ Rotary Cutter Identification??? #13
Mike : The cutter in my pic was not listed with a mdl #. I came accross it looking on Woods bushhog under all the images. vintage Woods bushhogs - Google Search
Also if you type in vintage Woods bushhog and look under images you will see others. woods bushhog - Google Search
Also WOODS 72-3, Used WOODS 72-3, WOODS 72-3 For Sale At TractorHouse.com - Page 1
Has some for sale,but they are 72- ? mdls.
Hope this helps you in your search.
Boone
/ Rotary Cutter Identification??? #14
to be honest, i would look more at the gearbox. (take cover off if need be) there should be some sort of plate or imprint on gearbox. to identify gearbox.
a local tractor dealer / tractor repair dealer. should hopefully be able to look up gear box number and figure out any pins/washers/bolts. you might want to get measurement for shaft diameter that drops down to the blade/blades. and possibly pull off PTO shaft from gearbox. and double check shaft size coming off of gear box there.
/ Rotary Cutter Identification??? #15
assuming the gearbox hasn't been changed out in something that old.
soundguy
/ Rotary Cutter Identification??? #16
kinda looks like an ole howse or king kutter to me... or an old ford bushhog
/ Rotary Cutter Identification??? #17
well that narrowed it down :) ;)
soundguy
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2016 Ford F-150 Crew Cab Pickup Truck (A61568)
2016 Ford F-150...
2023 HarbinGer V3 Plus S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2019 JCB 457 (A60462)
