Mowing Rotary cutter leaving half cut grass on the left side of the cutter
   / Rotary cutter leaving half cut grass on the left side of the cutter #1
DON11630
PANAMA CITY, FL
Massey Ferguson 240
Why does my 60" rotary cutter leave half cut grass on the left side of the cut and a nice cut on the right half of the cut? I am running at 540 at the PTO and I have slowed the tractor down to third gear. The cutter is level and new blades are on.
   / Rotary cutter leaving half cut grass on the left side of the cutter #2
are you sure it is level? pull out onto concrete. even a half inch height side to sde on the deck will stripe like that. most tractors have a leveling hnd crank to make up for that.
post back
   / Rotary cutter leaving half cut grass on the left side of the cutter #3
not sure if they are made in 60", but some cutters are made for 1000rpms, could be your issue but I doubt they are made that small.
   / Rotary cutter leaving half cut grass on the left side of the cutter #4
i'm not sure how rpm liek that type of difference would leave him striping?
   / Rotary cutter leaving half cut grass on the left side of the cutter #5
Probably from the tires packing the grass down. How tall is grass and is it wet? :confused:
   / Rotary cutter leaving half cut grass on the left side of the cutter #6
You are right, I was thinking about it more and had to come back.
I was thinking about the cutter turning ccw and the mower moving forward and the right side technically travelling faster.... I don't know why I was considering the tractor travelling speed having any effect on the cutting action- sorry, I am tired.
edit: that was in response to soundguy
   / Rotary cutter leaving half cut grass on the left side of the cutter #7
Any chance one of those blades is upside down?
   / Rotary cutter leaving half cut grass on the left side of the cutter #8
ARE YOU SURE THAT THE LEFT SIDE BLADE IS TURNING? PERHAPS THERE IS A SHEARED DRIVE KEY OR A BROKEN SHEAR BOLT THAT WILL ALLOW THE PULLEY ON THE LEFT SIDE TO SPIN ON THE PULLEY SHAFT, BUT WILL NOT DRIVE THE BLADE.
   / Rotary cutter leaving half cut grass on the left side of the cutter #9
Or did the blade just come loose and is spinning on the shaft giving you a partial cut?
   / Rotary cutter leaving half cut grass on the left side of the cutter #10
Another possibility..... make sure both blades are installed correctly!!! If one is on backwards, could that do it??
TEST YOUR BID BUTTON! (A51242)
TEST YOUR BID...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
1267 (A50490)
1267 (A50490)
2007 Ford F-150 Pickup Truck (A50323)
2007 Ford F-150...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
